I've been on a profiling journey since installed Caldera last week. I've read some helpful info on here today about restricting by measuring chroma which is simple enough in Easy Media. The result however of using peak chroma is that the necessary ink limit breaks Caldera's suggested rule that the ink limit should not be less twice the average individual limit (/half the sum of the limits). At the total ink limit that meets this rule the result shows heavy coalescing and bleeding. Eg. peak chroma for my Roland XC540 on monomeric SAV (720VD, 8 pass+ RIPC) occurred at 70/85/90/75% Pmax, but total ink limit should really have been around 140%.
Originally I was just limiting by eye, but when I did carry through the whole process using peak chroma the gains in estimated gamut reproduction were fairly significant. But of course the profile wasn't much good in terms of pooling and bleeding.
Qn 1. Is there a method/measure/rule of thumb I should be using for picking restrictions, or do I need to go to the extent of downloading Profilemaker and measuring back ~1 deltaE from the peak?
Qn 2. So far I've just been using the bleeding target after setting total ink limits, but are there other useful targets I should be using during the process?
Qn 3. Do others just leave Easy Media's suggested light ink transitions, or do you reduce them back knowing that you'll likely be restricting channels in the linearisation?
