Reverse Cutting
I am using Signlab 8 and a Roland VP300 printer/cutter. I am trying to figure out what I need to do in order to do a reverse cut. Any info anyone?
~Hayley @ Southern Vermont Sign Company
J Hill Designs
reverse - cut usually just comes into play when weeding - draw a box, cut, reverse weed...unless you mean mirror...then IDK i dont use that software/hardware combo
Ok. I am trying to make the sticker stick to a car window from the inside of the car; not the outside of the vehicles window. Not sure if that helps.
tsgstl
been a few years since I used Signlab but if I remember correctly you can
select
grab a corner (or any node for that matter)
hold shift and ctrl and go the opposite way
shift keeps it square
ctrl keeps it in check sizewise
