Reverse print on clear, laminate with white then cut. But how?
Discussion in 'General Signmaking Topics' started by PrintItBig, Oct 16, 2020.
  1. PrintItBig
    PrintItBig Member
    230
    Sep 29, 2012
    UK
    Hi,
    We want to reverse print some window graphics on clear vinyl, laminate with white vinyl and then have our Summa cutter cut them out. I’m sure this is possible but not sure of the best method to get the cutter to be able to access the dots that are now hidden under the white vinyl.
    Do we need to cut away a portion of the white vinyl that is covering the marks?
    Or is there some other way?
    Thanks.
  2. balstestrat
    balstestrat Member
    350
    42
    28
    Aug 25, 2020
    Europe
    Sounds like the easiest thing to do to me. If you have the width you can also move the marks further away from the graphics so you have more room to apply the white.
    • Agree Agree x 3
    • Like Like x 2
  3. White Haus
    White Haus Formally known as RJPW..........
    612
    169
    43
    Apr 6, 2018
    Winnipeg
    As mentioned, manually creating/moving your marks outside your white material is probably the simplest width. Or just create a bounding box outside your print area so your marks move out.
    When we've done this on our Rolands I would just mask off the 4 targets but Summa uses more so that wouldn't be much fun.
  4. balstestrat
    balstestrat Member
    350
    42
    28
    Aug 25, 2020
    Europe
    You can reduce the amount of marks for Summa as well (in onyx for example) in projects like these. May not be as accurate but if it's easier and one doesn't mind..
  5. White Haus
    612
    169
    43
    Apr 6, 2018
    Winnipeg
    Interesting, I never thought of this. Where would these settings be changed? Can all marks be edited/changed? Reason I ask, when we print onyx/summa barcodes on our flatbed, it always wants to put them on the top and bottom, which wastes material. I've been manually creating marks with Summa plugin which works, but I'm curious to see if I can somehow change that in Onyx.
    Thanks.
  6. balstestrat
    balstestrat Member
    350
    42
    28
    Aug 25, 2020
    Europe
    Open up the RIP. Go to the top left dropdown menu (can't remember the name) -> Cutter settings -> Select your cutter and Configure -> You can disable barcode and set the distance between the marks.
    That's all you can do.
  7. White Haus
    612
    169
    43
    Apr 6, 2018
    Winnipeg
    Thanks, will have a look!
  8. MI Bearcat
    MI Bearcat Member
    80
    10
    8
    Apr 1, 2015
    Canton, Michigan
    Do you have the flat bed applicator? We just cut the white vinyl to go inside the marks and apply with the flat bed applicator so the white vinyl is not covering up the registration marks
  9. RICHARD SIMMONS
    RICHARD SIMMONS Member
    91
    11
    8
    Jul 12, 2019
    Panama city, Panama
    Hi ! What I do is cut 3 mm little squares of black vinyl and place them over the ones printed. You can put a light under the print, so you can see the square printed. Then, the Summa will see and read the squares. Good Luck !!
  10. Superior_Adam
    Superior_Adam Member
    226
    39
    28
    Dec 13, 2017
    Wichita, Kansas
    you can cover the registration marks with a small piece of masking tape. After you apply the white carefully cut the white vinyl where the masking is and remove the tape which will expose the registration marks. Another method would be apply black vinyl where the dots are over the white. I find it is easier to tape under with masking.
    • Agree Agree x 1
  11. Boudica
    Boudica Member
    379
    116
    43
    Dec 21, 2018
    Spokane, WA
    Yep, that's how I do it
  12. WYLDGFI
    WYLDGFI Merchant Member
    1,288
    142
    63
    Oct 27, 2006
    Linden, NJ
    We would run as Mirror print....white ink backup and then go to our Graphtec or Colex. Much easier process. Doing full windows or such....we print mirror than lam with white vinyl and trim to image.
    • Like Like x 1
  13. eahicks
    eahicks Magna Cum Laude - School of Hard Knocks
    2,477
    350
    83
    Apr 17, 2012
    DALLAS, TEXAS
    Simply print mirror on clear, with a border about 1" around your image. Then when you print, the reg marks are well far way from the print. Cut your backing white vinyl the same size as the border box you printed and laminate it. Your reg marks are clear and ready for the plotter.
  14. IsItFasst
    IsItFasst Member
    375
    12
    18
    Jan 16, 2008
    USA
    I normally just create a white/clear box about 4 inches tall above and below what I am printing for the machine to skip over that area. That gives you plenty of room to apply the white just over the print. Wastes a little bit of material but I found it too time consuming and or error prone to try and remove the vinyl over the crop marks.
    • Like Like x 1
