RGB question...
54warrior
99% of what I design is only used online, so I use RGB colors. The problem I'm having is when I want to apply a "contour" to an object, it will default to CMYK colors, even though I have the main palette set to RGB. Does anyone know how to change it so it defaults to RGB color throughout the program?
Thanks!
Sign_Boy
Does Corel have a save for web feature like Illy?
If so this will convert your colors to RGB, but they might not be exactly the way you want them or even web safe colors.
signage
54 warrior set your RGB palette as the default!
To do this click on the box at the top the place a check at set as default
