RJ-900X error 084 Y2 current
REFLEXUSA
realistic independent outside-the-box thinker
Does your machine have a lot of overspray?? it could get into the CR motor gear and if you get enough of it, it will start to grab the belt and make a velcro ripping sound. This can also gum up the CR driven pulley on the belt adjuster. Both the gear teeth and the pulley need to be cleaned of any residue overspray in the belt path.
I didnt see any mention of this part of the printer, so I thought I would share what we have run into on a similar run machine.
