Rocker Panel Lettering
Discussion in 'Vinyl' started by slappy, Jul 16, 2013.
  1. slappy
    slappy Very Active Member
    3,927
    3
    38
    May 31, 2005
    Earth
    Lettering the rocker panels on a truck (the lowest part of the door closest to the ground)
    What kind of vinyl?
    Should i use cast or can i get away with oracal 651? (cast is 2 mil and intermediate 651 is 2.5 mil) Not doing any curves.
    I do not have a laminator.... is there a clear to put on that i can cut with the plotter to protect it??
  2. Gino
    Gino Premium Subscriber
    33,329
    2,328
    113
    Jun 7, 2006
    PA
    Other than wrapping, we try to discourage any die-cut vinyl going down there. It gets dirtiest the fastest and is subject to everything the road can throw up on it. It takes a lot of punishment and generally looks bad no matter what the person does.
    If you must, I would letter it with whatever you want and put a clear gravel protection shield over top instead of laminating.
  3. slappy
    3,927
    3
    38
    May 31, 2005
    Earth
    thanks Gino. You da bomb :thumb:
    :smile:
