Hi again,
My problem is this: since new the tracking on my Rockhopper has been brutal. If you remove all the blades (wings?) then it will track well but you get inconsistent patterns in your print because the material doesn't fit flat enough.
With the blades on, Even new ones make it pull to one side and the print will end up 2 or 3% shorter than it should be. Obviously this makes paneling impossible.
Any thoughts?
Thanks, DK
Any thoughts?
Thanks, DK
