For Sale Roland AJ1000I - 104" Printer For Sale Roland
702 graphics
Roland AJ1000I 104" Printer For Sale - $8,000
Located in Las Vegas, NV
Email - Brennan@702graphics.com for more info.
We are moving to a smaller shop and do not have room for this printer.
It has been serviced and maintained by Graphics Pro Tech a Roland Certified Dealer in Las Vegas.
The printer prints great and included optional air filter.
  • 104-inch industrial high-speed inkjet printer
  • Print speeds of up to 968 square feet per hour
  • EcoXtreme ink available in two formulations
    • Eco-Xtreme i
      • Dense, rich colors in CMYK+LcLm
      • Superior ink bonding - Water, scratch, alcohol and UV resistant
      • Durable up to three years outdoors without lamination
      • Reduced odor
    • EcoXtreme LT
      • Dense, rich colors in CMYK + LcLm
      • Cost-effective
      • Developed for short-term applications
  • Precision graphics of up to 720 x 720 dpi resolution
  • Heavy-duty media feed and take-up system supports 220-pound rolls
  • High-capacity ink delivery system features one-liter cartridges
  • Automated maintenance systems ensures reliable performance and easy operation
  • Roland VersaWorks RIP software included
    • Easy-to-use graphical user interface
    • Roland Color System
    • Variable Data Printing
  • Integrated tri-heater and blower print-drying system comes standard
  • Features integrated Ethernet 10Base-T/100Base TX
Print Mode Resolutions AJ-1000i
Billboard 360 X 180 968 sfph (90 sq m/h)
High-Speed 360 X 180 484 sfph (45 sq m/h)
Standard 360 X 360 323 sfph (30 sq m/h)
High Quality 360 X 720 162 sfph (15 sq m/h)
High Quality Vinyl 720 X 720 65 sfph (6 sq m/h)
MODEL AJ-1000i
Printing method Piezo inkjet
Printing width 102-1/3" (2600 mm)
Acceptable media width 48" to 104" wide
(1220 to 2641 mm)
Conditions for usable media Maximum Roll diameter 9.8inch
Core inner diameter maximum 3inch.
Media weight under 100 kg (220lbs) and maximum thickness 1.0mm
Ink Cartridges Type Exclusive Roland EcoXtreme i or EcoXtreme LT
Capacity 6 Cartridges of 1000ml each
Colors 6 Colors (CMYKLcLm)
Printing resolution Max 720 dpi
Setting range for the heater temperature Pre heater 95 to 122F (35 to 50 C)
Print heater 95 to 122F (35 to 50 C)
Dryer 95 to 140F (35 to 60 C)
Distance Accuracy
(Distance accuracy is not assured when using the heater) Error of less than +/- 0.3% of distance traveled, or 0.3 mm, whichever is greater (Roland PET film, print traveled 1m, temperature 20C(68F), humidity 50%)
Interface Ethernet (10Base-T /100Base-TX, automatic switching)
Power-saving feature Auto sleep
Electrical source Printer unit : AC 200~240V +/- 10% 50 / 60Hz 10A
Dryer : AC 200~240V +/- 10% 50 / 60Hz 10A
Power Consumption Printing mode Printer: Approx 1600 W
Dryer: Approx. 2300 W
Standby mode Approx. 60 W
Acoustic noise level Printing mode 70dB(A) or less (According to ISO 7779)
Standby mode 40dB(A) or less (According to ISO 7779)
(with stands) 169-1/3" (4299 mm) [W]
43-7/8" (1115 mm) [D]
55-5/8" (1413 mm) [H]
Weight (with stands) 1319 lb (598 kg)
Recommended environment Power on Temperature 68 to 89.6F (20 to 32 C), Humidity 35 to 80 % (non-condensing)
