I have a Camm-1 GX-500 cutter and a Soljet III printer. I'm noticing a slight error when doing cut jobs that is really apparent when cutting decals with a black border. The designer is using a 0.03" offset, and that isn't enough.
I see the accuracy of the GX-500 is 0.2%, so if they media is 46 inches wide, I'm assuming that means it can be off 0.009 for width, if the job is 5 feet long, it can be off 0.012 inches. So it seems like 0.03 should be adequate. It seems like the plotter "scales" a little differently than the printer, I'm noticing it seems more accurate near the origin, and gets further off as it gets away from the origin.
I thought the cutter using the crop marks to calibrate skew and any slight differences in the printer width/length, but maybe that isn't true? Do I need to calibrate both the printer and the plotter? Or just calibrate the plotter? I'm not sure how to do either.
