Roland Camm-1 CX 24 ( will not cut long lenghts, only parallel to the cutter?
Palmetto Joe
Hi , recently purchased a used Roland Camm-1 CX 24,, cut great, but it will not cut in lenghts, (example: copy is 19" x 72" it will cut parallal not verticle? does anyone have any knowledge of this plotter? thanks
Terry01
Found this in another forum
In properties click on the advanced button.
Open the document options folder and click on properties next to media size settings.
Click on add new media size and give it a name eg vinyl.
In the white boxes you can change the width (max 584mm) and length (max 24998mm) to what you require.
Click OK
then apply"
