Tibones
Hello,
I recently purchased my first vinyl cutter - a Roland Camm 1 PNC 1000
I installed XP on a computer. I purchased a parallel port card and installed the driver.
I installed the driver for the Camm 1 from Roland's website.
I also installed a copy of Corel draw 8. Did a test type and set the outline to hairline and did covert to curves.
When I hit print and select the cutter. I get the following messages.
Please see attached image.
I ended up purchasing another parallel port cable just to make sure it was not the cable not allowing communication.
Help needed.
Thanks,
Help needed.
Thanks,
