Roland CJ-500 54" Printer/Cutter w/extras $2500
tiredcreations
Roland CJ-500 54" Printer/Cutter still set up with pigment inks but can easily be converted to use Roland Eco-Sol Max inks. New cutter strip installed, printheads, capping station & dampers only have 57 hours of print time on them. I did have a head strike while printing canvas that clogged a few of the nozzles but I think they can be recovered. This printer has seen very little use over the past few years. The test prints show some banding and nozzles not firing, I'm certain most of this can be corrected with some cleaning and adjustments, but it prints fine as is. I've noticed some inaccuracies when cutting small curved letters, but anything bigger cuts just fine. Ink cartridges are all almost full.
Comes with:
Power cord
Parallel cable
Roland color choice software w/profiles
(3) Unopened ink cartridges (Black, Cyan, Magenta)
(4) New Clean Cut 45 deg. blades (one installed)
(1) Like new Clean cut 60 deg. blade (used twice)
(1) New extra wiper
(1) New extra damper
(6) Cleaning cartdridges (ideal if you want to convert to solvent)
(1) New extra cutting strip
New brass caps & orings
A bunch of new sheet cut blades
and more!
Also have a few rolls of laminate some canvas, and small amount of coated paper & vinyl for this printer that I'll include.
Price $2500.00 firm. Located in Peoria, IL.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
