MerlinPrints
Hey guys and gals, noob here, just getting started in wide format digital printing....
I am currently in the process of converting an old Roland CJ-500 into an SC-500.
So far i have flushed all the pigment ink out of the machine.
My next step is to flush it with Roland Eco Solvent Cleaner Cartridges.
Then I plan to put in Some Roland Eco Solvent Max inks in it.
I know i need bigger tubes on the drain bottle, on the way, and heating pre and post, also on the way.
I know I will probably need new print heads, capping station, dampers, pump, and wiper. Just want to see if i can get lucky first.
I am just wondering how you change the dip switches on the motherboard to make it boot up SC 500...
Any help and advice will be appreciated, and you will be rewarded someday by someone elses kind help.
for your help in advance.
![Thank You :thankyou: :thankyou:](https://signs101.com/images/smilies-orig/standard/thank you.gif)
