PrintItBig
Hi,We have a Roland RE-640 and have issues with colour.If we print one thing on Monday and then the same thing on Tuesday the colour is quite often different. All settings, artwork, print material all exactly the same but the colour can and often does vary.That on it's own is frustrating enough but we could probably live with it. The main problem is we also get colour shifts in the same run. We do a lot of multi-panel type stuff (hoardings, exhibition panels etc) and the colour can often vary from panel to panel. These need to butt up against each other so it's very obvious. We did a small run of 3 panels recently with a yellow / gold bar of colour running across them. This bar ended up a different colour on each panel (Image attached). They were run all at the same time, one after the other with all settings the same.Does anyone have any ideas on what's causing this? Is this Versa-works or the printer itself? The printer is still under warranty so I'm going to call an engineer out again on Monday (last guy pretended he couldn't see any colour difference), just wanted to know if anyone had any suggestions?Thanks.
