Roland cut sheet after otput size
printlinne
Hello anyone.
We can use custom settings about page space after printing. Sample i start to printing 2 copy same file. İts automatic make 40 mm space i change it to 10 mm. 1 st copy after printing sheet cut normal but when start 2 th copy printing its add automatical 75 mm before print. How can i change this 75 mm size to 10 mm or other size? Its impossible in roland machnes?
my model sp-540i.
Thanks for reading
garyroy
Go to "EDIT"
Then "Queue A Settings"
Then "Printer Controls"
Then "General"
Click "Use Custom Settings"
Then put in "10 mm"
Then "OK"
That should get you what you want permanently
printlinne
Go to "EDIT"
Then "General"
Then put in "10 mm"
Then "OK"
i did before but dont working. Have screenshot u can see. when start to printing after sheet cut auto add 75 mm i dont know why.
garyroy
Take you pick.
I haven't done automatic sheet cut on my Roland's in 13 years.
Your needs may be different.
Costa Mesa Sign
Go to "EDIT"
Then "General"
Then put in "10 mm"
Then "OK"
What this guy said. That 30mm of savings will add up at the end of a roll.
While there is stability reasons to have a solid leading edge, the tailing edge is useless IMO so save the media.
MrDav3C
The tailing edge is important if you want to cut the job after lamination without the printer saying it's ran out of media when it attempts to scan the third and fourth crop mark. I use the custom settings regularly along with a perforated sheet cut to allow for unattended printing of multiple print / lam / cut jobs being fed onto the take up unit
