Roland Fj-52 printhead ?
Discussion in 'Roland' started by anozira02, Feb 11, 2010.
  1. anozira02
    anozira02 Member
    456
    2
    18
    Mar 23, 2009
    Prescott, arizona
    I am installing new print heads in my Roland fj-52. I received my print heads and it seams the the Ranking numbers show different from the existing ones.
    Was wondering if the Ranking numbers are different from one head to another?
    This is my first time for head installations, I wanna make sure I am on the right tracks......any ideas please feel free to comment on this
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    18
    yes they will all be different I believe...it's an issue with exact voltage needed on that particular head...
  3. anozira02
    anozira02 Member
    456
    2
    18
    Mar 23, 2009
    Prescott, arizona
    Thanks, that's what i wanted to know!
  4. sfr table hockey
    sfr table hockey Very Active Member
    1,212
    Jan 24, 2009
    Alberta
    Just make sure to write those numbers down and once installed don't forget to change the head rank numbers in the printer menu. Also all the alignment issues that go with a head change.
  5. mo_alhawary
    mo_alhawary Member
    40
    Nov 25, 2009
    Egybt
    I have new heads from china with no head rank on it can any one tell me what to do ?
  6. sfr table hockey
    1,212
    Jan 24, 2009
    Alberta
    Check down the left side (as if installed) for numbers that are written in black marker (on the black plastic). It is hard to see unless you have light reflect off the marker. You would think they could find a white marker or something better but they write it with a black marker. If you can't see anything then you might not be able to use them. If the head rank is not set correct then it can send the wrong voltage (I think) to the print head and it won't print correct or it will leave lines in the print. I don't know if it would blow something other than the head so it might not be worth the test seeing heads are only $110 for these printers.
