Roland for making pounce patterns.
Discussion in 'Roland' started by Salmoneye, Mar 20, 2011.
  1. Salmoneye
    Salmoneye Very Active Member
    1,243
    Anyone know if there is a pounce wheel or function that works well for making pounce patterns on a xc-540? If not I will just print patterns and pounce on a table but It would save some time if there is an attachment that works well.
  2. OldPaint
    OldPaint Major Contributor
    any POUNCE plotters ive ever seen, are slow!! you can draw it out on paper with a pen, pounce it with a wheel FASTER!!!!
  3. Colin
    Colin Major Contributor
    4,540
    18
    38
    Sep 16, 2004
    Earth
    What OP said. Draw it in reverse, and pounce by hand while the paper is placed over a piece of rigid insulation foam.
  4. Salmoneye
    1,243
    Thanks guys. Colin, what is the reason behind doing it in reverse?
  5. Colin
    4,540
    18
    38
    Sep 16, 2004
    Earth
    Because after you pounce it (on the reverse image) you then flip it over and give it a light sand by hand with about 120 grit. This removes the tiny little "mountains" of paper, and leaves you with the proper "holes" that you want for the powder to go through, and results in a better pounced image.
  6. Salmoneye
    1,243
    I knew about sanding the back, I just thought that you would print pattern normally and pounce, flip over and sand the back. I guess that the holes work better with the sanded part facing away from the substrate? Thanks Colin
  7. OldPaint
    i do em in the normal view.......dont see ant reason to reverse it.
  8. Colin
    4,540
    18
    38
    Sep 16, 2004
    Earth
    Maybe try it next time.
  9. Jillbeans
    Jillbeans Major Contributor
    14,457
    18
    38
    Dec 24, 2003
    Butler, PA
    My 4B was the absolute best plotter for making pounce patterns and I still have it hooked up in my garage. I always just reversed the layout then plotted, no need for sanding.
    With the Graphtec I pen plotted then hand-cut my last patterns with a pounce wheel (they do come in various sizes) and to be honest it sucked in comparison to the 4B patterns.
    I was told Graphtec does have a pounce attachment, which is one of the reasons I bought it, but have never been able to find one.
    Love....Jill
  10. OldPaint
    back before i had a plotter, i had a WIDE CARRIAGE 9 PIN TRACTOR FEED PRINTER. wife worked at a place that used the same 2 tone green lined paper and she would bring me the old runs that was 3-4" thick. i put em in the printer backside facing print side, and make pounce patterns on 14" wide paper, and then i would tape them together to get 30-40" tall patterns.
  11. studio 440
    studio 440 Member
    372
    50
    28
    Jul 19, 2010
    cali
    electro pounce the best
  12. sardocs
    sardocs Active Member
    580
    110
    43
    Jun 17, 2005
    pender harbour bc
    +1 for the ElectroPounce. I can pounce tiny pinstripe designs with real tight curves and scrolls and large graphics go really fast.
