Try adjusting the blade depth first.
Remove the blade holder (with blade in it) and draw a circle with it on some scrap material, when you got it weeding cleanly without cutting the backing, replace it in the machine and adjust the pressure accordingly. I trust that the blade is ok, I use a jewelers eye glass to check the tips of my blades, easier to see if they are blunt or tip broken.
