I just bought an 8-year old GX-24. It works fine after I've replaced the  blade, blade holder and the cutting strip. I also took in all a apart  and cleaned it as well as lubed all the gears, pinch rollers and both  bearings. The issue I'm having is with the plotter making a  grinding/squealing noise while it is feeding the material at a low speed  only. The noise occurs even with the pinch rollers up but it does get  louder when the rollers are down pressing against the feeding shaft.  I've checked and oiled both bearings on the sides of the shaft and have  taken out the 2 little plastic rollers in the middle under the shaft and  the noise was still there so it's not the little plastic rollers. I'm  wondering in any one of you had this issue and was able to resolve it.  I've found a video on youtube where a person has exactly the same issue.  Here it is Video Of GX-24 Making Noise
