Roland GX24 will not advance after cut?
SignProPlus-Chip
Flexi 8.1
I have "Advance after plot" checked in production manager and in the GX24 setup menu.
But it cuts, then returns to origin no matter what.
Any ideas?
WildWestDesigns
I might be wrong but I did not think there was a way to have the GX24 do that.
Mine doesn't return back to the origin after it cuts. It advances it to where you can trim it and do the next job.
However, I do not use Flexi, I either use Ai/Corel or I use their CutStudio Program. That would be the only difference that I could think of.
signsandtees
It is a limitation of Flexi 8.1 and the driver that flexi uses, I upgraded to 8.6 and its fine, also in 8.1 I had to tell the ploter to rotate so that it would cut the right way, in 8.6 I had to rerotate the orientation.
