Roland LEF-12 UV Printer - Anyone Own One
Discussion in 'Roland' started by gresults, Oct 31, 2013.
  1. gresults
    gresults Member
    109
    Jul 7, 2003
    Magnolia, TX
    I'm getting ready to purchase a LEF-12 and was wondering if anyone had one and could let me know what I'm getting myself into with it..
  2. jrsc
    jrsc Member
    144
    Sep 24, 2008
    NY
    I'm pretty sure I'm about to buy a direct color systems 1014uv. Saw it at SGIA last week. It just looks like there's so many possibilities.
  3. scuba_steve2699
    scuba_steve2699 Member
    287
    I just got one 2 weeks ago and am still testing / playing with it. Very impressive on what it can do and your mind will continually be seeing things and wanting to print on them.
    I am working on some blog, videos, training etc. on it so please let me know if you want a specific test run etc. and I will try to help out.
  4. xprinter
    xprinter New Member
    1
    Roland Lef-12 impressions
    I own this printer its been ard 18 mths now. It has indeed impressed me with its applications and visual results on various Materials - although there are several limitations when it comes to ABS-plexiglass Materials or especially metallic surfaces.
    For many of thes cases you need precoating application prior to Printing since the absorption and durability is not there unfortunately. Otherwise the Printing goes off easily fromte material - even though UV lamps are used to stabilise on it.
    One of my biggest disapointment is that ink is being spoilt by the machine itself throughout the automatic maintenance which is unavoidable so that ink does no stabilise into the pipes. UV ink being rather expensive till now - especially 220 cc ink cartridges for this model - I find it exhasperating to find out at the end of the month that half the Cartridge is being consumed by the machine throughout the unavoidable maintenance function of the machine!!
  5. DRamm76
    DRamm76 Member
    496
    1
    I don't think the cost per square foot comes off as expensive at all. Figure about 0.46 psf. If you're printing cell phone cases on an LEF-12. You can get 8 cases per bed. The bed is 1 square foot. That's also based on full coverage. So you're using LESS than $0.46 to print one bed. I don't think that's unreasonable at all.
    I have done extensive testing on remote control devices and hard plastics and when tested against the Mimaki, Direct and Pad Printing the Roland LEF beat them all in durability testing. I have results tested out by a large distributor of these products. They would print the surface with no primers, hand test them for 3 minutes, wipe them down with 409 cleaner and wipe them dry 20 times, let them sit in a room of 85% humidity for 3 hours and repeat the cycle. Roland outlasted the competition.
    It's a solid unit.
