Roland PC60
Discussion in 'Roland' started by Sinkers, Oct 27, 2009.
  1. Sinkers
    Sinkers Member
    25
    Jan 24, 2009
    Can anyone give me any info about this printer? eg. Age, problems, are parts and inks still available? Can these be used to print outdoor quality.
    Thanks:help
  2. BobM
    BobM Very Active Member
    2,146
    44
    48
    May 31, 2008
    Cape Cod
    I've have one a bought used 3 years ago. It has a new print head ($850) and servo motor ($275). I use it for emergency jobs and once in a while I will print out a sample job. It is a good machine, just old technogly. I use Merchant Members on this site for my printing needs.
  3. signguy 55
    signguy 55 Member
    293
    1
    Bought one back in '99, never have made any real money with it. Very expensive to run, slow, had to replace print head after a couple of years, mine now has another bad print head. I'm just keeping it for a backup plotter when my old Roland 960 dies. Technology has evolved tremendously since then, I'm sure you could still get the old ribbons. Quality of prints were good when I used it, ran it using Flexisign.
    Signguy 55
  4. encadtech
    encadtech Member
    106
    Sep 8, 2008
    Higganum CT
    The PC60 is ribbon based printer. It uses both wax and thermal ink cartridges. The cost to print is about 8 cents a square inch - $1.15 sq / ft. It will cut / print up to 24" widths. It is a good solution for printing spot whites and foil colors like gold and silver. IMO -Because the cost to print is higher than an average solvent/inkjet - it is truely aimed at being a decal machine - The heads on these machine are vulnerable to being scratched and damaged by dirt / particles on the media you are printing on. I would not run this printer in a dusty production space - it needs to be in a controlled print room or office. The machine itself works very well. Last time I checked new head cost is $600.00 + install.
  5. encadtech
    encadtech Member
    106
    Sep 8, 2008
    Higganum CT
    Oh yeah - cartidges are still available by roland or you can get refill kits from zero nine
