roland pnc 1000 mac g4+corel 11 need help
Birdblaster
Hi everyone,
I have just purchase a camm1 pnc 1000 roland cutter from ebay. I have corel draw 11 + g4 mac computer. I can't seem to find the needed driver nor do i know where to buy the needed cables. The manual did not come with the unit so i am unsure of where the setting need to be.
I am a nebie that purchased the machine to make signs for my small business. Is there anyone out there whom can point me in the right direction? can't wait to doing first cuting job, that should be real ez lol
thanks Birdblaster
geb
Maybe this link will help.http://www.roland.com/support/en/
My camm1 to a PC was hooked up with a serial port selection, with a null modem adapter attached to the cutter serial port. Parallel port didn't work for me.
In Corel, you may be able to use parallel port to print. OP has posted on this before.
You should have posted this topic in the Roland section.
George
Birdblaster
George
Thanks , the link is for musical equip, however when i figure out how to search op posting on this subject , i am thinking that those postings may hold the answer. thanks
OldPaint
mac'S are different....
i dont think it will work direct from corel like it does on a pc. PC enterpolates anything for the plotter as a HPGL....if you can emulate that on a mac....then it will work
Rodi
In Corel 11, you can export a file as HPGL Plotter File_Export_HPGL Plotter file. OR Command-E
Rodi
Birdblaster
Rodi
Rodi you all were right, there is a HPGL plotter export file that exports the file to i would imagine the plotter and bam it should cut i would think. now i have to figure out parallel or serial cable and the settings, George I hope your right thanks
Birdblaster
yeap i found the file havent tried it yet but i bet its going to work. what setting should i put it on, i dont have a manual
thanks birdblaster
Birdblaster
paint
I never could get that mac and corel 11 going, I need to make some signs so i have decided to go with the pc + corel 11. I have the driver for xp but for some reason i still cant get it to cut.
Do i need to save the file as HPGL then print, do I need to make the sign then just print it, how does corel draw work with the cutter Pcn1000
