Roland printerdriver for windows 8.0
DandM
Is there some one that knows where to find a printerdriver for Roland SP 540i
that works in windows 8.0 64 bit.
At this time i cant seem to install a driver in windows 8 "Dutch" ore any other version, if any one knows
let me know please thanks in advance.
SightLine
You will most likely need to wait for Roland to make a driver for it. Everyone that jumped on Windows 7 early had the same issue. Not just with Roland though..... Mutoh, Mimaki, Gerber, etc. I'd suggest NOT trying any new operating system in a business enviorment until you have first verified that your specific business machines and software actually are supported or at least work on the new operating system and have compatable drivers.
Andrew O
The Windows drivers offered for some of the early generation VersaCAMMs only controlled cutting. We do not have a printer driver. However VersaWorks should run in Windows 8. Let me know if you're having a problem installing it, and I will get someone from tech support to work through it.
