Roland SC-500 price
Discussion in 'Roland' started by bovegas, Jul 24, 2011.
  1. bovegas
    bovegas Member
    170
    1
    18
    Sep 6, 2008
    Des Plaines, IL
    What is realistic price for Roland SC-500 with take up reel, flexi training videos,one extra new head and printer server. Printer is in excellent condition, perfect test print. Thanks in advance
  2. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,847
    70
    48
    Feb 27, 2007
    World
    I'd say a buck 99 and some change.
  3. sfr table hockey
    sfr table hockey Very Active Member
    1,212
    Jan 24, 2009
    Alberta
    I would assume you have heat plates on that printer. Not all SC 500's did.
    If all is working well I would say you should get $6,000.00 plus. I know converted FJ's were going for as much as $5,000.00 and they are printer only.
    Non converted units have been around $3,000.
  4. bovegas
    bovegas Member
    170
    1
    18
    Sep 6, 2008
    Des Plaines, IL
    I am asking 6500 with everything
  5. NolaSignGuy
    NolaSignGuy New Member
    18
    I would try your luck selling it a bit higher on globalgarage.net and see what happens
  6. DRamm76
    DRamm76 Member
    496
    1
    Without a warranty attached, you would need to take into consideration that anyone who buys it has 6 heads and two very expensive boards to replace should they ever go bad. Total cost to get all that repaired even over the span of a year or two is about $10,000+
    Question is, how much would YOU pay for a machine that old and out of warranty. Ask yourself that and there's your answer
  7. sfr table hockey
    1,212
    Jan 24, 2009
    Alberta
    DRamm, this was on a SC500 (the older Roland 54") so it had the DX2 heads (which have gone up in price but still $200 range and only uses 2 heads) You may be right on boards if they ever go, they would be around $1,000) and if you can't do your own work the install is what gets you.
  8. bachaar
    bachaar Member
    26
    sj 645 et profile
    hi all
    i have sj 645 installed with ink triangle
    the quality of printing is bad
    i need some profile of this ink for vinyl macrac and 3M
    PLEASE HELP ME
    thanks & best regards
  9. Gabriel
    Gabriel Member
    275
    The ink supplier should help you in finding some ICC profiles for you.
  10. bachaar
    bachaar Member
    26
    yes i know
    i try with many profiles the just now i don't find the best that it give best quality
  11. bachaar
    bachaar Member
    26
    icc profile
    hi all
    anyone help me please
    i need profiles for roland machine sj 645
    ink: triangle
    vinyl : 3M
