Roland SC540 EX issue
JBT
Hello,
I'm a newbie and I wanted to know if anyone has a solution to this issue.
I have a used Roland sc540 and when I turn on the main switch in the rear it turns on the machine and goes to cleaning mode.
Then I get a scan motor error 0080 or 0010. When I attempt power off the unit using the sub power on/off panel button it powers
down and powers back up in cleaning mode. I can not power down from the panel. I hope I explained this clearly.
CS-SignSupply
Try to reinitialize the limit and cut down position
if it fails, run the scan motor aging
if that fails replace the scan motor
