Roland SC540 Print problem
well33t
Hi,
I am new to printing and I already got weird problem.
My color are all mixed up and I have no idea why
I had a problem one hose was disconnected ( cyan ) and I had to remove the panel and change the fitting and replug it.
Then the color got all mixed up after that. The thing that I find really weird is that when I do a test print directly on the printer, the color output are all good.
Can you guys help me please?
thanks a lot
attachment.php
attachment.php
well33t
it seems that my color are mixed up. I made a file in illustrator with different color separated. this is the result
Output from printer
attachment.php
File from illustrator
attachment.php
El Barto
Judging from the test prints your heads are firing in the proper order (and quite nicely, to boot). I'm guessing this is a data problem rather than a mechanical one. Did you remove any of the ribbon cables? Was it printing properly before you reconnected a hose?
well33t
Yes it was printing correctly before reconnecting the hose. I might have disconnected one of the cable by accident. I dont know where to look though. Which of the cable could be the problem ?
Desert_Signs
Are the heads in an SC540 in a different order than the XC540?
XC540 prints C M Y K lM lC.
kffernandez
check if the inkset settings in your SC-540 menu is correct. after that. check if it is also correct in your rip.
since it appears that all your heads are firing correctly, i will put my money on this issue being a configuration problem.
kelly
well33t
My inktype is set to "MAX cm" and I tryed Production manager with my last profile that was working. I also tryed a new one. Then I tryed versaworks with Generic vynil 2. Still having issue
I also changed my damper order. It was Black, Cyan, Magenta, Yellow. Now I switch it to C, M, Y,K and here's the result.
attachment.php
