EbsWeb5150
When u use a Roland SP540 and your graphic is done printing and u have it set up to contours cuts around your graphic. If at that point u choose to weed out the remaining unused vinyl and from there u were to then laminate the graphic would u have to hand contour cut around the vinyl?
With other printers u need 3 pieces of equipment.
The Printer
The Cutter/plotter
The Laminater
What is the standard operating procedure with a Roland and a laminater
to get it to contour cut around the laminated graphic
The Printer
The Cutter/plotter
The Laminater
