roland sp-540v won't conect
Discussion in 'Roland' started by flagstaffprinting, Jan 20, 2009.
  1. flagstaffprinting
    flagstaffprinting New Member
    12
    all of my printers and computers are working fine except for the roland? anyone have any answers? i start up versa and it says that it's not connected
  2. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    Need more to go on here bud. Have you had it working before? Is this the first time to connect it? Have you moved it or anything to a new location? Do you have the Roland Print-Server software installed?
  3. flagstaffprinting
    12
    ya it has been runing reall good ever since i have got it. i was having problems with the internet so i got a new router and since than [yesterday] it won't work but all the other printers work fine
  4. ChiknNutz
    4,789
    2
    Since you just noticed the problem with the new router, using "Akums Razor" (the simplest explanation is usually correct), you may have some setting in the router that's not allowing the printer to be seen. I don't use VW, but in Wasatch I have to set up the IP address of the printer. I'd say they with the new router, it has changed the IP address of the printer. Can you "see" the printer in the Roland Print-Server software?
  5. flagstaffprinting
    12
    actually were back to using the old router but with a defferent switch. how do u change the ip for it.
  6. ChiknNutz
    4,789
    2
    You have to use the Roland Print-Server software to change the IP...that's why I kept asking about this software.
