Roland Sp300 Could Not Cutting
Discussion in 'Roland' started by FALCON, Jan 22, 2020.
  1. FALCON
    FALCON Member
    46
    1
    8
    Mar 14, 2019
    United State
    Hi, my device does not do any cutting commands, also the sheet cut button does not work! Only the cut test button works. What do you think is the problem?
  2. FALCON
    FALCON Member
    46
    1
    8
    Mar 14, 2019
    United State
  3. FALCON
    FALCON Member
    46
    1
    8
    Mar 14, 2019
    United State
    Not Have Solution?
  4. Joe House
    Joe House Active Member
    962
    213
    43
    Feb 5, 2004
    WA
    If it's cutting with the test cut button, then it would appear that the printer is capable of cutting. As a test, try the cut test at different points across the platen. If it cuts all the way across, then it's probably a file or RIP issue. If it doesn't cut all the way across, then you probably need a new cut carriage cable.
    When you say the sheet cut button doesn't work - does it do nothing? or does the carriage go across, but it doesn't cut off the vinyl?
    Be aware that many parts for that printer will be difficult if not impossible to find as Roland has stopped supporting it. Be careful about dumping too much money into it as you may not be able to get it working if the problem gets back to being a main board issue or something like that.
    Good Luck
    • Like Like x 1
  5. FALCON
    FALCON Member
    46
    1
    8
    Mar 14, 2019
    United State
    Sheet cut button is mechanically no problem I opened the panel and checked it, There is no reaction when pressing or hold it
  6. eahicks
    eahicks Magna Cum Laude - School of Hard Knocks
    2,477
    350
    83
    Apr 17, 2012
    DALLAS, TEXAS
    You hold the Sheet Cut button down for a couple seconds and nothing cuts?
    • Like Like x 1
  7. FALCON
    FALCON Member
    46
    1
    8
    Mar 14, 2019
    United State
    Yes
  8. FALCON
    FALCON Member
    46
    1
    8
    Mar 14, 2019
    United State
    Yes
