Roland SP300V not printing all the colors
Discussion in 'Roland' started by anwarshah, Feb 2, 2009.
  1. anwarshah
    anwarshah Member
    26
    Jan 23, 2009
    houston
    :omg:
    I just changed the pump on my Roland SP300V due to the problem of not printing yellow. When printing the color bar it prints CMMK instead of CMYK.
    When the pump was being changed, there was a lot of ink near the old pump.
    After successful installation of the pump, and several "Medium Clean" around 4 times and twice "Powerful Cleans" it still prints CMMK. I was told by a tech to use a syringe to suck out the ink near the CAP. But hardly anything comes out.
    Anyone know what the problem is?
  2. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    How long has it been since the cap tops were replaced? I change mine out every 6 mos. This may not be the issue, but it could contribute to it.
    So you are saying that where Yellow should be printing it is printing Magenta. FYI, Cyan & Black share a head and Magenta & Yellow share a head. Sometimes I've had CK and MY get mixed up for a little while duirng some cleaning, but it usually gets resolved pretty quick after cleaning better. Do you manually clean it or just from the control panel?
  3. txsurfer
    txsurfer Member
    284
    Oct 29, 2005
    Texas
    create a large square 100Yellow and print until the yellow starts printing, we had this issue before the magenta had contaminated the yellow
  4. anwarshah
    anwarshah Member
    26
    Jan 23, 2009
    houston
    What are caps? In 3 years I've replaced a pump once and the wipers twice and wiper scraper once. I clean manually as when the need arises. My printing is very low vulume.
  5. anwarshah
    anwarshah Member
    26
    Jan 23, 2009
    houston
    Can you be more specific on "creating a large square 100Yellow"?
  6. tanneji
    tanneji Member
    497
    create a large square that has 100% yellow and 0% CMK and then print that over and over again until magenta gets cleared out of the yellow head
  7. ChiknNutz
    4,789
    2
    Hard to believe, but okay. I manually clean 2X per week whether it "needs" it or not. Here is a link to what "cap tops" are:
    http://www.cmykparts.com/10002794.html
  8. anwarshah
    anwarshah Member
    26
    Jan 23, 2009
    houston
    Thanks a bunch, I'll try it now.
  9. high impact
    high impact Very Active Member
    Sounds like cap tops...if you don't know what they are then I would definitely start there! We change ours once a year at minimum!
    The cap tops are what seals the heads when they park...the rubber breaks down and then the heads don't seal any longer.
    oops...I see I was two minutes late. hahaha
  10. anwarshah
    anwarshah Member
    26
    Jan 23, 2009
    houston
    Many thanks. Where can I find information on replacing caps?
  11. ChiknNutz
    4,789
    2
    Service Manual. Do a search for one. I had to hunt for mine, you can too.
  12. Robert M
    Robert M Very Active Member
    1,325
    12
    38
    Jan 23, 2007
    colorado
    Cap Tops
    I sell the cap tops, 32.95
    tech manual is free.
  13. anwarshah
    anwarshah Member
    26
    Jan 23, 2009
    houston
    Sounds good. Is that for one cap or both and is it OEM?
    Let me know how to buy
  14. Sign Works
    Sign Works Very Active Member
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    You also might want to check your yellow ink cartridge to make sure it is not empty, occasionally they do not work properly to let the printer know that they have run out of ink.
  15. Sign Works
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    Also did you upgrade the printer's firmware for the new pump? I just replaced the pump on my 2 1/2 year old SP-300V and it was a newer style pump than the original and required a firmware upgrade.
