Hi everyone,
I'm having a problem with my Roland SP-300v as of late. It's printing grainy, especially on smaller photo type images. It's not an image resolution thing as I've been repeatedly printing the same art for years and only somewhat recently has the grainy print been an issue. Smaller photo-type images have always been a bit grainy but not this bad and it seems to be getting progressively worse (image attached showing a print from a few weeks ago compared to today). Even my larger spot-color-type graphics are printing a bit grainy, but it's not as noticeable as the smaller photo ones.
It's difficult to see, but there are heavier and lighter dashes in the test print (especially cyan). Is it possible the nozzles are slowly narrowing (not fully clogged, but building up with ink and narrowing so the test print lines are slightly thinner in areas)?
I switched from Roland to aftermarket ink many years ago with no issue (I've used the same local house brand for years). However, I did recently install an inexpensive ink from sign-in china. The problem seemed to exist before, although maybe not as bad, but maybe the cheap ink accelerated the problem? The grainy issue seemed to sneak up on me so I can't say exactly when it started.
I tried the coffee filter head soak for about 30 minutes but didn't get any improvement. Should I be soaking longer? Is the coffee filter soak the best way or is there a better soaking method. The heads are old but I haven't had any other issues with them other than this grainy issue now.
Is this grainy printing how heads slowly fail?
Could it be bad ink? And if so, could switching ink solve this or is the damage already done to the head nozzles?
Any help on this would be greatly appreciated. This forum has always been extremely helpful.
Cheers!
Cheers!
