So far..Black/Cyan was not printing, so - completed ALL head cleaning processes then replaced capping stations + dampers & wipers. Flushed all lines to/from pump, flushed cleaning fluid direct thru nipples on heads, have clamped hose from caps to pump & filled capping station to soak heads. Swapped Blk/Cyan printer ribbons to Mag./Yellow on the print heads PCB (disaster - M/Y was printing OK now it's not printing at all).
Tested Fuses F2 + F3 on the Main Board and they are OK - Seems like an elecrical problem in the Blk/Cyan Head ribbon/Head Board/Main Board. What next?? Any suggestions are welcome.. Local techs are only replacement salesmen.
