Roland Versaworks Won't Read Cut Lines. Please Help!
kmajid
Good morning to all! Hope everyone is doing well on this Wednesday.
For some reason i can't get Versaworks to read the cut lines in the files attached. Every now and then that happens and I end up Flattening the transparency which typically fixes the problem. The same is true here but the problem is that the images change and i can't get them back to the way they looked before.
Hopefully the above makes sense and if you can help out please let me know. Thanks so much.
  • iPhone 4 Prime Group Test.pdf
kmajid
Perfect. Can't thank you enough, but for future reference can you let me know what i would need to do in case i run into such a problem?
Custom_Grafx
PM received.
Solution is transparency option in "custom" area.
"convert all strokes to outline" box was checked.
Unchecking fixed problem.
Vantage Point
First off I want to say thank you for the explanation.
We were working on a file to contour cut a drawing and that check box was the problem.
I am new to the forum but have been finding fixes to problems here. Finally decided it was time to be a member.
