Need Help Roland VG-640 cutting issues
r_frost2002
Hey. I have a Roland VG-640 and it's cutting oddly. If I batch print stickers and contour cut, it seems to cut accurately at the front right (starting point) of the sheet, but the further left and back it goes the farther it gets off. On a 2ft print, the back left is off by about 1/8 of an inch. Does anyone know what causes this and how I can fix it? Thanks!
Jim Hancock
Old School Technician
Check the condition of your pinch rollers, especially the outer rollers. They are a common cause of media shifting during contour cutting.
rjssigns
Before you drive yourself crazy with cutting issues buy a dedicated plotter. I owned a Roland and cured all my contour cut issues the day my Summa showed up. Granted my Roland was older, but Roland print/cut devices have never been known as the go to for contour cutting.
Bii Emmanuel
Check the condition of pinch rollers while plotting check if the media is sliding.
Also check the offset position setting on the machine.
Kah Hou
Hi, have u managed to solve the issue ?
