Roland VG2 - Intermittent service calls, bad test prints
Discussion in 'General Signmaking Topics' started by Jonathan Tyrell, Nov 22, 2019.
  1. Jonathan Tyrell
    Jonathan Tyrell New Member
    7
    Nov 10, 2019
    United Kingdom
    Hi guys,
    We've had our Roland VG2-540 for around 2 months now.
    It has been printing great until this morning.
    When we got into the office in the morning, the machine was beeping and said service call 0012.
    Switched off the machine, switched it back on, manual clean and it was printing perfectly again.
    After a few prints, I queued up another print.
    After the head went across the media for the first pass, the machine started beeping and gave another service call: this time service call 0110.
    Again, turned it off and on.
    Did a test print, it was terrible (see attached).
    Then did thorough manual clean, normal clean and then a perfect test print again!
    What could be the issue?
    I noticed that there was a lot of ink around the print heads, even on the second manual clean (even though they'd just been cleaned an hour ago).
    I've attached a picture of the swab on the second clean of print heads.
    Would appreciate any help! IMG_20191122_203110710_HDR.jpg IMG_20191122_205614736_HDR.jpg
    Many thanks,
    Jonathan
  2. Rick Tennyson
    Rick Tennyson Member
    114
    15
    18
    Sep 14, 2019
    Mid-South
    Other than this issue, how do you like your machine overall?
  3. player
    player Major Contributor
    4,915
    189
    63
    Apr 24, 2006
    Toronto
    It should be free service call under warranty?
  4. Jonathan Tyrell
    7
    Nov 10, 2019
    United Kingdom
    Hi, yes it would be covered under warranty but machine is now back to normal, so just wondering what the issue could have been.
    The machine prints and cuts exceptionally however we got it because it was an 'all-in-one' machine;
    However it is a massive pain to wait 24 hours for outgassing. Also the inks are not scratch-resistant so we have to laminate. Then we have to put the prints back into the machine to cut, while it could be printing something else. Smell of the prints is very bad even with door/window open. Cleaning is also quite a pain, emptying waste bottle and manual cleaning twice a week. So print quality is great, but I would sacrifice a little quality and get a UV/latex printer in hindsight. Maybe they'll come with their own issues so I don't know.
    If anyone has any thoughts on the service call codes / why the issue could have occurred, would appreciate it!
    Also you can PM me if you want any further info on the VG2.
  5. SignMeUpGraphics
    SignMeUpGraphics Moderator
    1,365
    290
    83
    Apr 11, 2012
    Australia
    So it's a VG with a new name... so much for the promises of resolving the issues it had.
    • Hilarious! Hilarious! x 2
  6. ewded
    ewded Member
    496
    89
    28
    Aug 28, 2017
    UK
    By now it should be VG377 if they'd have renamed it after every major bug.
  7. ams
    ams Very Active Member
    2,227
    301
    83
    Oct 28, 2010
    Virginia
    Service Call: XXXX
    An unrecoverable error occurred or part replacement that must be performed by a service technician is required.
    Action: Confirm the number displayed, and then switch off the sub power. After you switch off the power, inform your authorized Roland DG Corp. dealer of the number that appeared on the display.
  8. Jonathan Tyrell
    7
    Nov 10, 2019
    United Kingdom
    I just turned it off and on again, and it started working...
    But don't want it to happen again that's why asking on forums if anyone has any input :)
  9. Jonathan Tyrell
    7
    Nov 10, 2019
    United Kingdom
    Where were you before we bought the machine :p
  10. ewded
    ewded Member
    496
    89
    28
    Aug 28, 2017
    UK
    Trust me you can find a ton of post me telling about my issues with the VG540, in the meantime I learned one thing - if you need a good printer go with epson.
    • Agree Agree x 2
  11. Jonathan Tyrell
    7
    Nov 10, 2019
    United Kingdom
    I thought VG2 they'd have solved all the issues :(
    Do you still have your VG-540?
    Or changed it for an Epson?
  12. ewded
    ewded Member
    496
    89
    28
    Aug 28, 2017
    UK
    Changed to Mimaki CJV150 which was a great machine, not too fancy, not too fast but reliable and affordable. Now I print on an Epson 60800 and its just crazy fast and quality is comparable to offset. You can laminate right away, I just leave 5-10 minutes to be be on the safe side.
  13. John at Aegis QP
    John at Aegis QP New Member
    18
    Mar 7, 2019
    San Diego
    As has been suggested, get that free service call. If the printer or you are slammed with work try to schedule it at the most convenient time you can. Problems that just 'go away' tend to return at the worst possible moment (in order that Murphy's Law is conserved.) And as a new VG2 owner I'd say you want to know if the tech can intercept a failure mode that is festering in the weeds. Just sayin ...
    John
  14. p_vassilis
    p_vassilis New Member
    11
    1
    3
    Nov 29, 2012
    Greece
    The first error (0012) is a power voltage error. It does not reach the required voltage on turning the sub power on. I wouldn't expect this error with the sub power off (as it was in your case?).
    The second error is related to the linear encoder or the motor stop moving. Regardless of the printer working, you should notify your dealer.
    • Hilarious! Hilarious! x 1
  15. SignMeUpGraphics
    1,365
    290
    83
    Apr 11, 2012
    Australia
    If you were on this forum before you bought the machine you would have seen pleeeeeenty of reports of similar issues with the VG range.
