Roland VP540 wastage
solantis
When printing on a sheet thats 1250 wide my machine says the media is only 1140 wide. How can I rectify this or work around it because when im printing an A2 I cant place one next to the other and end up wasting material
rjssigns
What RIP? Do you ask the RIP to get media width? VW will default to the last size if you don't ask it to check.
Rednapew
Wastage on a Roland simple solution... possibly
Hi ... first thing I thought of is the rollers and media position... are your rollers positioned at the edges of your material or even half on the material (needs perfectly square alignment of your media/vinyl) the printer/cutter will read where the outside rollers are... NOT the edge or the media... after the machine finishes the "Setup" process... check your RIP software settings (Roland Versaworks) in "Layout" click "Get Media Width" button... hope that helped...
solantis
Thanks guys. The problem was that I was not positioning the media correctly to get the most out of the material. I've played around with the configuration a bit and im getting the last few mm in :)
