Roland VS-300! no inkt out printhead.
Nico Hendrickx
Hi everyone,
I'm new here. I recently bought a second-hand Roland VS-300i. The seller said that only the print head was completely clogged due to lack of use.
The printer did all the rest.
Now after a few days of searching I still can't get a drop of ink out of the print head. The pipes are open, ink drips out of the damper connection. New damper, properly working print head, no ink.
I suspect that my motherboard is damaged. Are there people here who have experience and repairing a printed circuit board? Yes, where can I go for that? I'm from Belgium.
Thanks everyone.
DJAvocado
Hi everyone,
Thanks everyone.
Are you using aftermarket ink?
damonCA21
Did you replace the print head?
If you run a powerful clean look to see if there is ink coming out into the waste bottle. If there isn't then the head is blocked.
It could be a mainboard problem, or the print carriage board has failed, but this is less common. I do repairs to mainboards if you need it. I am in the UK but do repairs for customers all over the world. Feel free to DM me if you want more information.
Nico Hendrickx
Hello sir,
can you send me a e-mail? nico_hendrickx@hotmail.com
What I did:
dampers and head are now ok. => working at other printer.
When I disconnect the connector of the pipe on the damper, the ink drips from the pipe.
With an "ink circulation" I see the metallic up and down in the pipe, but nothing comes out of the print head. The captop still looks like new after 2 days, no ink to be seen.
I think, the only solution mainbord damage.
Best regards,
Nico Hendrickx.
damonCA21
Did you try doing a powerful clean from the control panel? That will let you know if ink is flowing through the head properly. If no ink comes out into the waste bottle then it is a problem with the ink getting through the heads, and not a mainboard problem
damonCA21
Hello sir,
What I did:
Best regards,
Nico Hendrickx.
Have also sent you an email, or you can use the private messages on here
cornholio
Sounds like the captop doesn't make good contact with the head surface, or the pump doesn't work.
Which probblem it is can be checked by sucking at a tube with a syringe.(while closing the second tube)
If you can easily fill the syringe with air, there is a problem with the cap.(cap position can't be adjusted officially, but you can try, if you moved the position before)
Nico Hendrickx
The head has ink in the meantime, and the captop discoloured with ink. Yet I still get no ink on the vinyl. In the meantime I discovered that the mainboard is defective. It is to a repairer who will repair it.
guillermo
hope this will help you.
My friend had an RS640, printhead stop firing the red color on only one side, he did everything possible to get it back, but no luck, he ended up selling the machine to the vendor he got it from, he just replaced the print head and sold it.
