Roland XC-540 cutting error
Discussion in 'Labels and Decals' started by E Coloney, Aug 12, 2019.
  1. E Coloney
    E Coloney Member
    99
    14
    8
    Dec 14, 2014
    USA
    Using print and cut later as opposed to print and cut (now). Cut contour is off by 2+ mm but checks out fine when calibrating it. I just don't get it. Help!!
  2. C5 Service&Repair
    C5 Service&Repair Member
    308
    38
    28
    Jan 14, 2018
    Omaha, NE
    How are you calibrating it?
  3. MBO_1
    MBO_1 New Member
    7
    1
    3
    Feb 2, 2019
    Belgium
    TIP
    A/I always put 3 horizontal lines (i use the lines on the front of the machine where the vnyl is on) on both sides with a pen before i start printing.
    Afterwards when i put the vinyl back in the printer I make sure the lines match, so i am certain that the vinyl is in the same position as it was when starting printing.
    Then i positon the cuthead to the mark genereated by the software.
    When doing so this has helped me in cutting afterwards.
    B/ Only adjust in the job in the ripsoftware from print to cut (do not change any other settings. So do not touch button Get Media Width or any other buttons).
  4. E Coloney
    E Coloney Member
    99
    14
    8
    Dec 14, 2014
    USA
    Calibrate using Roland Service Notes for XC-540 (number at bottom: 70031-14), section 4-10 Crop-Cut Adjustment. This is pretty much spot on but when I use the print/cut with crop marks on an actual project the cut is more than 2mm skewed.
    Appreciate your reply.
  5. E Coloney
    E Coloney Member
    99
    14
    8
    Dec 14, 2014
    USA
    Is there any other reply/input?
