Hello,
I just purchased a Roland XC-540 used and I have been running a Roland SC-545EX for years so I am familiar with the Roland printers. I am running into a lot of issues with registration marks and alignment...
some time it reads the marks no problem but cuts off as it feeds out; even after doing a full calibration. Other times it wont find the marks at all and I go through the whole process and manually align the marks and I hit cut, it tries to find the marks itself anyway and cant find them.... I don't see the point with the manually finding the points if it dose it on its own. And further more I don't care for the fact the you can just set up the sheet to find the marks first then hit cut. you need to align the base point and hope it finds the points and if not you need to reload the sheet and do everything all over again. At least with the SC-545EX you knew if your crop marks would work or need to be manually input before getting the versa works involved... lol
is there something I didn't set up on versa works at would help or is this a problem with everyone and you just need to keep resetting up the sheet after every failed attempt?
as for the alignment issues I have calibrated the printer and it seems to be dead on until I go to cut?
I am running Windows 10 up-to-date
Versa works V5.5.1
ROLAND XC-540
and ROLAND SC-545EX (which still runs Great)
Any Insight would be greatly appreciated!
Regards,
Brandon
Versa works V5.5.1
ROLAND XC-540
Regards,
Brandon
