Roland XC540 Air Purge
crny1
Well if you have more solaris cartridges throw them in to see what it says. If you have some OEM laying around take the chip off them and put on the solaris to try and trick the machine.
First thing I would do is try to get it cooled off in the shop or the machine atleast. There is no way the machine likes those temps and may be causing some issues.
C5 Service&Repair
its saying wrong cart because when you do a pump up, the machine expects you to remove all ink from it. Now by doing a fill ink, its telling you to swap the carts with cleaning carts "CL" so it can prime the ink lines with cleaning solution before pulling ink to the heads.
