Roland Xj 740 printheads misaligned when parked on cap tops
swirls
It would be in the regular menu usually abbreviated, "ENV MATCH." It's very possible that your machine is one of the ones that does it automatically behind the scenes but it won't hurt to look in the menu just in case.
I went through the menu and it’s not there.
swirls
Did you turn machine off and then back on after doing any settings adjustments? Need to do that to save all settings.
Internal Error 1942091 could be caused by a variety of factors (e.g. flushing adjustment, encoder scale/sensor issue, belt tension, etc
Internal Error 1942091 could be caused by a variety of factors (e.g. flushing adjustment, encoder scale/sensor issue, belt tension, etc)
Can you explain the flushing adjustment? Came in today and the carriage drifting is happening.
swirls
Hi All.
Just an update...
After getting these error codes, I went more in-depth in my search for the cause.
I ended up taking a closer look at the belt pulley system (left and right ones) and noticed the rod that goes through the center hole (left pulley) had a play in it. I ended up changing the pulley and to my surprise it didn't have that play again and I did a whole setup again, from limit initialization, linear encoder test, etc.
So far, I haven't had any issue... (knock on wood).
Thanks to the members who made comments and valid input.
Cheers to the weekend!
