roll holder location
Discussion in 'Graphtec' started by cardfan4342, Mar 27, 2007.
  1. cardfan4342
    cardfan4342 Member
    108
    What location height wise on the roll holder on a fc7000-75 do most use with as little jerk and smoothest cutting. I believe there are 4 possible locations. have been using the second down from top and experience occasional reload media errors because of jerking. I try to pre feed material but sometimes forget or get busy mid cut any advice would be appreciated :thankyou: Doug
  2. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Must always prefeed enough not to jerk the motor on any plotter !
    Tough to remember, but after a few dozen yards of vinyl, you'll remember !
  3. Neil
    Neil Member
    333
    11
    18
    Aug 25, 2005
    Adelaide, South Australia
    I've got mine at the top on the rear of the machine.
    Still need to pre-feed the roll though - no way out of that.
    I'm considering swapping over to front loading so it's easier to load & unload a roll and also easy to manually unwind by hand rather than using the keypad.
    Anyone out there using front load? Good or bad?
