rolling cut and weeded vinyl
Tovis
IS cut and weeded vinyl suppose to be rolled with the vinyl on the inside or outside or does it not matter.
Tovis
Is that because it the factory does it on the outside and it retains the memory from that?
Outside....if absolutely necessary.
I hate rolling masked vinyl! I ship flat whenever I can...but as we all know it's not always an option!
MikePro
not so much of a memory thing as it is simply to keep your vinyl from tunneling. (lifting from backing in lines across the material)
Graphics2u
Outside. That way if anything tunnels it will be the backing and the vinyl will still be relatively flat when installing. And roll it in as large a diameter as posible.
Sticky Signs
+1. I hate it when people send me stuff rolled image side in. Makes the install 10 times harder.
Graphics2u
and is that even before it has x-fer tape put on it?
Primarily after transfer tape is applied. If rolled with vinyl out before transfer tape applied it likely won't tunnel, but you risk the cut vinyl getting caught or stuck to the backing paper when rolled up, especially if there are small pieces or sharp points in the cut vinyl.
Malkin
It would generally only tunnel after the transfer tape is on.
Also, rolling vinyl that has been cut & weeded, but without tape, is asking for trouble as corners will catch and stick.
