As I said I have no backlash comp on it now. Will ck for tightness and add 5 thousands to y and see how it ends up.Your file looks ok once I got it loaded. They are poly arcs all the way through.
I would next suspect stepper lash at specific points on the table for those marks to be so consistent. Have you tried running the job with no bit plunge to see if the spindle looks shakey around the curves?
I willYou should start by testing out some squares and circles, there might be some play in your stepper or gantry.
So your spindle is shaking with no load going around the table?
is so 1 check your racks for debris and lube it, they check your motors for catch points... you may need to replace them if they can't be rebuilt. Shouldn't be expensive unless you need a new driver.
Its funny but the amount of play between the spur and barrel gear were exactly the depth of the ridges I was finding in the work piece. Learn something new everyday. .So I discovered on the left side y axis stepper, the gear is quite loose. I can turn the reduction gear and see it move chatter against the spur gear on the stepper. I will tighten that up right away. Im also changing the position of the spindle in the clamp. Right now its protruding almost all the way out. I have enough Z to set it higher up in the clamp to improve stiffness. Will rerun file after this and report back. Thanks sooo much to everyone who has added their 2 cents to the conversation.
Appreciate your help 2CTWell that is good news, hopefully your issue is solved.
Any time, I didnt do much!Appreciate your help 2CT
Ok, I know someone out there has had this problem so looking for advice. This is an older 4x8 router we have and just learning the process etc. Using Artcam and Mach 3. My edges always seem to have chatter for lack of a better term creating ridges in the edges. As I said the router is older. R&P X and Y w Ballscrew for Z. Mach 3 has backlash compensation in it but currently have it set to 0. Am I correct in assuming that's what this is? Any help much appreciated.
See this machine has no belts it's a spur gear off of stepper to a reduction gear which is connected by shaft to pinion gear on rack. It has an offset flange that you rotate to increase tension. It was loose on one side of y. Tightened and cleaned it right upI say it is a loose belt on the gantry. There are two motors that control the y move, and one (probably on top) that controls the x move.
You just have to loosen the retaining nuts that establish the tension on the gears (i.e., that keeps them in contact with the rails) and pull the motor further away to effectively tighten the belts. It'll take two people, one to pull the little motor to increase the tension, and another to tighten the bolts back down while still overtensioning. On these older machines, the belts can stretch, and thus make this type of problem. You can also just replace the belts. At least it's a cheap shot...
