GAC05
Quit buggin' me
Hi all,
Looking for some tips on getting good results chamfering the edge of thin 1/8" or 3mm Lexan (Home Depot).
I need to put a clean 45-degree edge on it that I can use to join 2 pieces with some acrylic solvent cement.
I have a DeWalt cordless trim router with a carbide 45dg edge trimming bit set in a table I made, with a solid fence to guide the material into the bit.
With just trimming the edge and not cutting into material this thin, is the rule of thumb slow spindle and slow feed or go fast on the spindle rpm to get a smoother result?
I ran a few test scraps but I don't know what I am doing just yet. The Dewalt can go from pretty slow to scary fast. At high speed, I feel like I need to count fingers after each pass to make sure they are all still there.
The router seems to cut best when going from right to left with the bit poking up through the table. The other way wants to grab and launch the material off the table.
This is the end of the moon project so I don't want to screw up the faces with the finish line in sight.
Thanks for reading
Thanks for reading
