I was wondering what type of masking anyone might be using, specifically for routing and painting afterward. I typically use Gerber Mask I for most of my work on painted substrates, which are then routed and then painted and/or gold leafed in the routed areas. Lately though, I've been having some trouble with the mask not adhering well on the cut edges, which has been allowing some paint bleeding and poor results. Recently this has been with straight cut edges; previously I've never had a problem with incise cut edges. Also, I've done some spray painting with Krylon and some automotive primers and paints in the routed areas but that immediately peels the mask material right off the substrate. Typically I'd be using One Shot enamel with their Universal Primer, which usually hasn't been any problem. I'd appreciate any input if anyone has had good success with any other mask material or has any other insight here....thanks!
