run time errors/ memory could not be written
Discussion in 'Flexi' started by brichard, Mar 24, 2006.
  1. brichard
    brichard New Member
    1
    I am relatively new to flexi, I have cut out close to 200 signs and all of a sudden the production manager seems to not be working anymore. When I hit the cut button, a run time error message comes up followed by two memory could not be written memos. I have tried a lot of things like checking cables, restarting, taking out hardware key, etc. Does anyone else have any suggestions?
  2. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    First have you restarted your computer?
    If that is not the problem go to the directory where Flexi is set to store its temp files make sure that the old files have been removed some times old files will cause problems.
    Another thing you can try is to clear preferences.
  3. signage
    signage Major Contributor
    9,493
    71
    48
    Oct 5, 2005
    Penn
    Try disabling firewall/anti-virus. What security programs are you running, operating system. should fill out this section of profile.
