Safety Speed Dustless Cutter will not cut ACM straight
Discussion in 'Miscellaneous Hardware' started by Gary Welch, Oct 8, 2020.
  1. Gary Welch
    Gary Welch Member
    25
    1
    3
    Apr 10, 2007
    Hermiston Oregon
    I have a Safety Speed Dustless cutter (Multi substrate cutter). I have tried for years to get it to cut straight. I can put the knife in and get it cutting Foam Core straight, but when I put the wheels in for cutting ACM It is off by 1/4 inch or so. Any ideas or experience with this?
  2. VisualArtsImaging
    VisualArtsImaging New Member
    12
    3
    3
    Nov 24, 2016
    Palm Springs, CA
    Assuming you have squared the frame per instructions? Is your silicone grippers in tact under the hold down bar?
  3. FireSprint.com
    FireSprint.com Trade Only Screen & Digital Sign Printing
    Clamp the ACM down firmly in several spots. Use something like a quickclamp It's likely twisting while your cutting it.
    • Agree Agree x 1
  4. Dan360
    Dan360 Member
    479
    100
    43
    Dec 23, 2014
    Ontario, Canada
    We have the same problem with our Excalibur when cutting aluminum. The amount of pressure causing it to twist as FireSprint mentioned.
    I found lubricating the wheels helps quite a bit. Also if someone is around, I'll have them lean onto the pressure bar as I cut it.
  5. Reveal1
    Reveal1 Active Member
    558
    178
    43
    Nov 7, 2010
    Cape Girardeau, MO
    Same problem with our Keencut - the clamps Firesprint mentions are the way to go.
