SAI files with excessive points
Ok, here is my issue. If I import a file (never had an issue using and plotting from casmate) and bring it into SAI (subscription, so its current) it adds hundreds of extra points. Even if i create a file in SAI and change the text slightly, it adds hunreds of excessive points. It takes so much longer to plot!!
What used to take 3 minutes a sheet, now takes almost 10 minutes.
Why does SAI files ADD points to an eps file?
Is there a way around it???
Getting very frustrated. Now taking hours to recreate/cleanup every file.
And is I use the "eliminate points tool" it removes either not enough to make a difference or it changes the font too much!!
